HelloDespite carefully examining all information I could get hold onI didn't find the formula which converts byte 3 and byte 4 of I2Creadout into a temperature !Who knows where to find it or how to do it ?Thanks in advanceWalter
Hello Walter,
Please let me inform you that the on-chip temperature sensor comes calibrated using 3 temperature points : -40 Celsius degrees, room temperature (RT) and +125 Celsius degrees.
Regarding the equation to convert the raw temperature to Celsius Degrees please check the Technical Note below:
https://www.renesas.com/us/en/document/tcb/zsc31014-tn-calibration-sequence-and-dll-description?r=179821
Hope it helps.
IK_Renesas
