Certificate to use for dropbox https api call
I tried sample code available on link-> http://gadget.renesas.com/en/reference/lychee/grlibs_tls.html
for HTTPS post request which is working fine.
Now I want to make same HTTPS Post request to Dropbox so which certificate should I used from link ->
https://github.com/dropbox/dropbox-sdk-python/blob/master/dropbox/trusted-certs.crt
when I tried with second global certificate I got error on serial monitor:
----- HTTPS POST request -----
Connecting to content.dropboxapi.com:443
Starting the TLS handshake...
mbedtls_ssl_handshake() failed: -0x2700 (-9984): X509 - Certificate verification failed, e.g. CRL, CA or signature check failed
HttpRequest failed (error code -1)
Below screenshot of sample code certificate usage
Or, is there any other way to use GR Lychee to make https post request?
  • Can you try with this key,
    -----BEGIN CERTIFICATE-----
    MIICPDCCAaUCEHC65B0Q2Sk0tjjKewPMur8wDQYJKoZIhvcNAQECBQAwXzELMAkG
    A1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMTcwNQYDVQQLEy5DbGFz
    cyAzIFB1YmxpYyBQcmltYXJ5IENlcnRpZmljYXRpb24gQXV0aG9yaXR5MB4XDTk2
    MDEyOTAwMDAwMFoXDTI4MDgwMTIzNTk1OVowXzELMAkGA1UEBhMCVVMxFzAVBgNV
    BAoTDlZlcmlTaWduLCBJbmMuMTcwNQYDVQQLEy5DbGFzcyAzIFB1YmxpYyBQcmlt
    YXJ5IENlcnRpZmljYXRpb24gQXV0aG9yaXR5MIGfMA0GCSqGSIb3DQEBAQUAA4GN
    ADCBiQKBgQDJXFme8huKARS0EN8EQNvjV69qRUCPhAwL0TPZ2RHP7gJYHyX3KqhE
    BarsAx94f56TuZoAqiN91qyFomNFx3InzPRMxnVx0jnvT0Lwdd8KkMaOIG+YD/is
    I19wKTakyYbnsZogy1Olhec9vn2a/iRFM9x2Fe0PonFkTGUugWhFpwIDAQABMA0G
    CSqGSIb3DQEBAgUAA4GBALtMEivPLCYATxQT3ab7/AoRhIzzKBxnki98tsX63/Do
    lbwdj2wsqFHMc9ikwFPwTtYmwHYBV4GSXiHx0bH/59AhWM1pF+NEHJwZRDmJXNyc
    AA9WjQKZ7aKQRUzkuxCkPfAyAw7xzvjoyVGM5mKf5p/AfbdynMk2OmufTqj/ZA1k
    -----END CERTIFICATE-----
    let me know if not working...
    Ritesh
  • I tried with your suggested key here is what I am getting on serial monitor:
    mbedtls_x509_crt_parse() failed: -0x262e (-9774): X509 - Signature algorithm (oid) is unsupported : OID - OID is not found
    HttpRequest failed (error code -9774)
  • Okay! that should work actually but that's okay,
    MIIEtjCCA56gAwIBAgIQDHmpRLCMEZUgkmFf4msdgzANBgkqhkiG9w0BAQsFADBs
    MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3
    d3cuZGlnaWNlcnQuY29tMSswKQYDVQQDEyJEaWdpQ2VydCBIaWdoIEFzc3VyYW5j
    ZSBFViBSb290IENBMB4XDTEzMTAyMjEyMDAwMFoXDTI4MTAyMjEyMDAwMFowdTEL
    MAkGA1UEBhMCVVMxFTATBgNVBAoTDERpZ2lDZXJ0IEluYzEZMBcGA1UECxMQd3d3
    LmRpZ2ljZXJ0LmNvbTE0MDIGA1UEAxMrRGlnaUNlcnQgU0hBMiBFeHRlbmRlZCBW
    YWxpZGF0aW9uIFNlcnZlciBDQTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoC
    ggEBANdTpARR+JmmFkhLZyeqk0nQOe0MsLAAh/FnKIaFjI5j2ryxQDji0/XspQUY
    uD0+xZkXMuwYjPrxDKZkIYXLBxA0sFKIKx9om9KxjxKws9LniB8f7zh3VFNfgHk/
    LhqqqB5LKw2rt2O5Nbd9FLxZS99RStKh4gzikIKHaq7q12TWmFXo/a8aUGxUvBHy
    /Urynbt/DvTVvo4WiRJV2MBxNO723C3sxIclho3YIeSwTQyJ3DkmF93215SF2AQh
    cJ1vb/9cuhnhRctWVyh+HA1BV6q3uCe7seT6Ku8hI3UarS2bhjWMnHe1c63YlC3k
    8wyd7sFOYn4XwHGeLN7x+RAoGTMCAwEAAaOCAUkwggFFMBIGA1UdEwEB/wQIMAYB
    Af8CAQAwDgYDVR0PAQH/BAQDAgGGMB0GA1UdJQQWMBQGCCsGAQUFBwMBBggrBgEF
    BQcDAjA0BggrBgEFBQcBAQQoMCYwJAYIKwYBBQUHMAGGGGh0dHA6Ly9vY3NwLmRp
    Z2ljZXJ0LmNvbTBLBgNVHR8ERDBCMECgPqA8hjpodHRwOi8vY3JsNC5kaWdpY2Vy
    dC5jb20vRGlnaUNlcnRIaWdoQXNzdXJhbmNlRVZSb290Q0EuY3JsMD0GA1UdIAQ2
    MDQwMgYEVR0gADAqMCgGCCsGAQUFBwIBFhxodHRwczovL3d3dy5kaWdpY2VydC5j
    b20vQ1BTMB0GA1UdDgQWBBQ901Cl1qCt7vNKYApl0yHU+PjWDzAfBgNVHSMEGDAW
    gBSxPsNpA/i/RwHUmCYaCALvY2QrwzANBgkqhkiG9w0BAQsFAAOCAQEAnbbQkIbh
    hgLtxaDwNBx0wY12zIYKqPBKikLWP8ipTa18CK3mtlC4ohpNiAexKSHc59rGPCHg
    4xFJcKx6HQGkyhE6V6t9VypAdP3THYUYUN9XR3WhfVUgLkc3UHKMf4Ib0mKPLQNa
    2sPIoc4sUqIAY+tzunHISScjl2SFnjgOrWNoPLpSgVh5oywM395t6zHyuqB8bPEs
    1OG9d4Q3A84ytciagRpKkk47RpqF/oOi+Z6Mo8wNXrM9zwR4jxQUezKcxwCmXMS1
    oVWNWlZopCJwqjyBcdmdqEU79OX2olHdx3ti6G8MdOu42vi/hw15UJGQmxg7kVkn
    8TUoE6smftX3eg==
    try this also, if this will not give you successful output then you need to go through dropbox's documentation completely
    Hope this works,
    -Ritesh
  • Ritesh, Thanks for help
    I think I have found right certificate which is now working,
    "-----BEGIN CERTIFICATE-----\n"
    "MIIDxTCCAq2gAwIBAgIQAqxcJmoLQJuPC3nyrkYldzANBgkqhkiG9w0BAQUFADBs\n"
    "MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\n"
    "d3cuZGlnaWNlcnQuY29tMSswKQYDVQQDEyJEaWdpQ2VydCBIaWdoIEFzc3VyYW5j\n"
    "ZSBFViBSb290IENBMB4XDTA2MTExMDAwMDAwMFoXDTMxMTExMDAwMDAwMFowbDEL\n"
    "MAkGA1UEBhMCVVMxFTATBgNVBAoTDERpZ2lDZXJ0IEluYzEZMBcGA1UECxMQd3d3\n"
    "LmRpZ2ljZXJ0LmNvbTErMCkGA1UEAxMiRGlnaUNlcnQgSGlnaCBBc3N1cmFuY2Ug\n"
    "RVYgUm9vdCBDQTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAMbM5XPm\n"
    "+9S75S0tMqbf5YE/yc0lSbZxKsPVlDRnogocsF9ppkCxxLeyj9CYpKlBWTrT3JTW\n"
    "PNt0OKRKzE0lgvdKpVMSOO7zSW1xkX5jtqumX8OkhPhPYlG++MXs2ziS4wblCJEM\n"
    "xChBVfvLWokVfnHoNb9Ncgk9vjo4UFt3MRuNs8ckRZqnrG0AFFoEt7oT61EKmEFB\n"
    "Ik5lYYeBQVCmeVyJ3hlKV9Uu5l0cUyx+mM0aBhakaHPQNAQTXKFx01p8VdteZOE3\n"
    "hzBWBOURtCmAEvF5OYiiAhF8J2a3iLd48soKqDirCmTCv2ZdlYTBoSUeh10aUAsg\n"
    "EsxBu24LUTi4S8sCAwEAAaNjMGEwDgYDVR0PAQH/BAQDAgGGMA8GA1UdEwEB/wQF\n"
    "MAMBAf8wHQYDVR0OBBYEFLE+w2kD+L9HAdSYJhoIAu9jZCvDMB8GA1UdIwQYMBaA\n"
    "FLE+w2kD+L9HAdSYJhoIAu9jZCvDMA0GCSqGSIb3DQEBBQUAA4IBAQAcGgaX3Nec\n"
    "nzyIZgYIVyHbIUf4KmeqvxgydkAQV8GK83rZEWWONfqe/EW1ntlMMUu4kehDLI6z\n"
    "eM7b41N5cdblIZQB2lWHmiRk9opmzN6cN82oNLFpmyPInngiK3BD41VHMWEZ71jF\n"
    "hS9OMPagMRYjyOfiZRYzy78aG6A9+MpeizGLYAiJLQwGXFK3xPkKmNEVX58Svnw2\n"
    "Yzi9RKR/5CYrCsSXaQ3pjOLAEFe4yHYSkVXySGnYvCoCWw9E1CAx2/S6cCZdkGCe\n"
    "vEsXCS+0yx5DaMkHJ8HSXPfqIbloEpw8nL+e/IBcm2PN7EeqJSdnoDfzAIJ9VNep\n"
    "+OkuE6N36B9K\n"
    "-----END CERTIFICATE-----\n"
    now getting below response:
    Just need to workout on proper URL request, will let you know my progress and if any help needed
