Hi , i have some problems about using Mandrill library . i am trying to replace email library with Mandrill library to avoid the limit of 20 mail/per hour,
i try the sample code to send my email,but i encounter the problem of smtp port,can i change the port from 465 to another one(25, 587 or 2525)?
i have check my Mandrill user name and API key, but i still can not solve my problem,is there any step i miss?
thanks for reading my problem.
Hi jason5773,
As what it says here, you can also use port 25, 587, or 2525 as long as you're not using encryption. Did you try changing the port using the telnet command?
JBRenesasRulz Forum Moderator
https://renesasrulz.com/https://academy.renesas.com/https://en-us.knowledgebase.renesas.com/
