Renesas software can't find E2 Lite debugger
I'm trying to set up my working environment for my masters thesis using the RH850 board with an E2 lite debugger.
Sadly, i can't download the code to my board in CS+ for CC using the debugger, because the IDE can't find the debugger device.
 The device manager shows the device properly and all drivers are installed.
I tried several software products like the flash programmer or the diagnostic tool for the E2 lite but everytime the debugger is not listed.
While the E2lite is plugged in the green ACT LED is blinking, otherwise nothing is visible.
Hopefully someone can help me.
[locked by: Herald at 13:14 (GMT 0) on 5 Aug 2021]
