I use USB port in CDC-ACM device mode with the S128 DK board (R7FS128783A01CFM) . In usbx device configuration I can change the product id and vendor id values, but I need change this values by code. I'ts possible change the value by code to configure automatically configuration.xml?
Thanks in advance.
Hello Pabmoo!
How's it going? I am not so sure if this is possible to be done by code, maybe you can try to refer to the sample code here. I also hope our experts can verify this. Thank you for your patience.
All the best!
SaiRenesasRulz Forum Moderator
https://renesasrulz.com/ https://academy.renesas.com/ en-support.renesas.com/knowledgeBase
