I try to generate binary file, but the generated file size is very big.
For example, the "quickstart_ek_ra2l1_ep" project, the HEX file is 74k, SREC file size is 79k, but binary file size is 16,449k.
I change the output file format via: "C/C++ build" =>"Setting" =>"GNU ARM Cross Create Flash Image" =>"Output file format" =>select "RAW binary".
Is there other way to converter file to Binary?
Hello Rabbit. Please take a look at the below threads which address the binary file size issue. https://community.renesas.com/embedded-system-platform/synergy/f/forum/17230/bin-file-too-large
https://community.renesas.com/embedded-system-platform/synergy/f/forum/11314/make-bin-file-synergy-project-as-generated-file
https://community.renesas.com/embedded-system-platform/synergy/f/forum/19660/how-to-control-the-size-of-compiler-output-file-hex/64702#64702
-JayeshIf this response, or one provided by another user, answers your question, please verify the answer. Thank you!Renesas Engineering Community Moderatorshttps://community.renesas.com/https://academy.renesas.com/en-support.renesas.com/.../
