I create a user bootloader, but the hex and bin size is much bigger than elf as blow, can you give some help on this? thanks
Hello Jali. You can take a look at the below threads which mention the same issue.
https://community.renesas.com/embedded-system-platform/synergy/f/forum/17230/bin-file-too-large
https://community.renesas…
https://community.renesas.com/embedded-system-platform/synergy/f/forum/11314/make-bin-file-synergy-project-as-generated-file
https://community.renesas.com/embedded-system-platform/synergy/f/forum/19660/how-to-control-the-size-of-compiler-output-file-hex/64702#64702
-JayeshIf this response, or one provided by another user, answers your question, please verify the answer. Thank you!Renesas Engineering Community Moderatorshttps://community.renesas.com/https://academy.renesas.com/en-support.renesas.com/.../
Thanks Jayesh, it works!
