Configurator can't assign customer name to pins
I try to assign customer name for MCU pins,
for example (P001 ==> AN001, is for Temperature sensor 1 analogue, I would like set its name to "AN_TempSensor"),
                    (P002==>AN002, is for Pressure sensor analogue input, I would like set its name to "AN_PresureSensor").
It will be easy to read the code if with customer name.
But I can't set it in "configuration.xml", any suggestion?
Sam
