BLE Bonding Issue with DA14531 as BLE Central Device
**Hi Support Team,**
I am working on a project that uses the DA14531 as a BLE Central Device. We are planning to use the BLE Bonding feature, leveraging the BLE Security Layer to ensure secure data transmission. The user callback configuration events are set up as follows:
```c
static const struct app_callbacks user_app_callbacks = {
.app_on_connection = user_on_connection,
.app_on_disconnect = user_on_disconnect,
.app_on_update_params_rejected = NULL,
.app_on_update_params_complete = NULL,
.app_on_set_dev_config_complete = user_on_set_dev_config_complete,
.app_on_adv_nonconn_complete = NULL,
.app_on_adv_undirect_complete = NULL,
.app_on_adv_direct_complete = NULL,
.app_on_db_init_complete = user_on_db_init_complete,
.app_on_scanning_completed = user_on_scanning_completed,
.app_on_adv_report_ind = user_on_adv_report_ind,
.app_on_connect_failed = user_on_connect_failed,
.app_on_get_dev_name = default_app_on_get_dev_name,
.app_on_get_dev_appearance = default_app_on_get_dev_appearance,
.app_on_get_dev_slv_pref_params = default_app_on_get_dev_slv_pref_params,
.app_on_set_dev_info = default_app_on_set_dev_info,
.app_on_data_length_change = NULL,
.app_on_update_params_request = user_gapc_param_update_req_ind_handler,
.app_on_generate_static_random_addr = NULL,
.app_on_svc_changed_cfg_ind = NULL,
.app_on_get_peer_features = NULL,
#if (BLE_APP_SEC)
.app_on_pairing_request = default_app_on_pairing_request,
.app_on_tk_exch = user_app_on_tk_exch,
.app_on_irk_exch = NULL,
.app_on_csrk_exch = default_app_on_csrk_exch,
.app_on_ltk_exch = default_app_on_ltk_exch,
.app_on_pairing_succeeded = user_app_on_pairing_succeeded,
.app_on_encrypt_ind = NULL,
.app_on_encrypt_req_ind = default_app_on_encrypt_req_ind,
.app_on_security_req_ind = NULL,
.app_on_addr_solved_ind = default_app_on_addr_solved_ind,
.app_on_addr_resolve_failed = default_app_on_addr_resolve_failed,
.app_on_ral_cmp_evt = default_app_on_ral_cmp_evt,
.app_on_ral_size_ind = NULL,
.app_on_ral_addr_ind = NULL,
#endif // (BLE_APP_SEC)
#if (BLE_APP_SEC)
static const struct app_bond_db_callbacks user_app_bond_db_callbacks = {
.app_bdb_init = NULL,
.app_bdb_get_size = remote_bdb_get_size,
.app_bdb_add_entry = remote_bdb_add_entry,
.app_bdb_remove_entry = NULL,
.app_bdb_search_entry = remote_bdb_search_entry,
.app_bdb_get_number_of_stored_irks = remote_bdb_get_number_of_stored_irks,
.app_bdb_get_stored_irks = remote_bdb_get_stored_irks,
.app_bdb_get_device_info_from_slot = remote_bdb_get_device_info_from_slot,
We have a BLE Peripheral device that also uses the DA14531, and we have successfully tested the BLE Bonding functionality with a mobile app.
**Testing Issue:**
I tested the bonding connection on the BLE Central device. It successfully connected and bonded with the BLE Peripheral device on the first BLE connection, triggering the **app_bdb_add_entry** event. However, during the subsequent disconnect/connection cycle (without resetting or power cycling the BLE Peripheral), it still requested the bonding event again, triggering the **app_bdb_add_entry** event. This behavior is unexpected as it should remember the bonding information.
Upon further investigation and debugging, I found that it does not trigger events to check the existing bonding information in RAM memory (such as **app_bdb_search_entry**, **app_bdb_get_number_of_stored_irks**, and **app_bdb_get_stored_irks** function callbacks). Instead, it only requests bonding from the SDK.
Can you provide guidance on how to resolve this issue so that the bonding information is correctly remembered across connections?
Thank you for your assistance.
