DA14531 Keil
Hello. I have a few questions based on your answer in the link above. All software can be opened in Keil. I want to debug the software while opening it in Keil. Can't I do it through Keil? If I can, how should I do it? If you have the relevant documents, I would be happy if you shared them.
Good day.
Hi ylmaz,
Please refer this tutorial:Tutorial Dialog SDK 6.0.x Debugging — DA145XX Tutorial SDK Getting started (renesas.com)
Any further questions are welcome.
BR,
JH_Renesas
Thanks for your answer. While doing this step, we encounter the problem in the image. How can we overcome this problem? I would be happy if you provide support.
Have a nice day.
Hi There,Thank you for the reply.Please go on Options for Target-->Utilities and then make sure that "Use External Tool for Flash Programming" option has been selected.After this you should be able to attach the debugger as expected:Best Regards,OV_Renesas
Hello OV_Renesas When I do what you say, I get this response. How can I fix it? Thank you for your support.
Hi There,Thank you for the reply.The Error seems pretty generic since it does not mention the exact issue.This error pops up after you built you project? Where you able to attach the debugger?Best Regards,OV_Renesas
