DA14531 connection with generic sensor
Hi everyone,
I am working on a project where a DA14531 device on a custom board needs to connect to a generic external BLE sensor, not part of this device family. I am using the template provided by the example BLE_SDK6_examples/connectivity/central/. Running the example, the sensor is obviously scanned (I modified some filtering settings compared to the default SCAN_FILTER_NAME with "DLG-PROXR"), but I can't figure out how to modify the code so that, when the sensor is scanned, a connection procedure starts (similar to what happens by default in target_apps/ble_examples/prox_reporter). The name ad BD address of the sensor are known.
Thanks for your time!
  • Hi Seba,
    Let me describe the procedure below:
    1) The DA14531 starts scanning. After booting up, we configure the BLE stack. When the BLE stack has been properly configured, the user_app_on_set_dev_config_complete callback function will be executed. In that callback we call the ble_scan_for_devices API.
     * @brief Callback from SDK once stack is configured
     * @return void
    void user_app_on_set_dev_config_complete(void)
    		/*Advertising starts within this default handler, but we have made the callback NULL to avoid advertising.
    		* alternate method, would be to copy the default handler code into here, removing the advertising call
    		default_app_on_set_dev_config_complete();
    		ble_scan_for_devices();
    		spi_flash_power_down(); //power down flash before entering sleep
    2) While we scan, we receive the advertising reports. The reports are being handled in the user_on_adv_report_ind callback function. By default, we have set some SCAN macros so you can filter the devices you have found.
     * @brief Callback from SDK when we get the advertising report.
     * @param[in] report  advertising report information
     * @return void
    void user_on_adv_report_ind(struct gapm_adv_report_ind const * adv_ind)
    	bool dev_found = false;
    #if CONNECT_TO_PERIPHERAL == 1
    	bool conn_to_device = false;
    	struct bd_addr dev_addr = adv_ind->report.adv_addr;
    #endif
    	uint8_t num_ad_elements = user_ble_gap_get_adv_num_elements(adv_ind->report.data,
    																																		adv_ind->report.data_len);
    	ble_gap_adv_struct_t adv_data_structs[num_ad_elements];
    	user_ble_gap_parse_adv_data(adv_ind->report.data_len, adv_ind->report.data, adv_data_structs);
    	uint8_t i;
    	for(i = 0 ; i < num_ad_elements; i++)
    		switch(adv_data_structs[i].type)
    #if SCAN_FILTER == SCAN_FILTER_NONE
    			case GAP_AD_TYPE_FLAGS:
    				dev_found = true;
    				dbg_block_printf("GAP FLAGS: %s\r\n",
    													format_hex_string(adv_data_structs[i].data, adv_data_structs[i].len) );
    				break;
    #endif
    #if (SCAN_FILTER == SCAN_FILTER_NONE)
    			case GAP_AD_TYPE_MORE_16_BIT_UUID:
    				dev_found = true;
    				dbg_block_printf("INCOMP LIST 16-BIT SVC: %s\r\n",
    				break;
    #endif
    #if (SCAN_FILTER == (SCAN_FILTER_NAME) || SCAN_FILTER == SCAN_FILTER_NONE)
    			case GAP_AD_TYPE_COMPLETE_NAME:
    				dev_found = true;
    				char local_name[adv_data_structs[i].len + 1];
    				format_adv_string(adv_data_structs[i].data,adv_data_structs[i].len, local_name);
    				dbg_block_printf("Device Local Name: %s\r\n", local_name);
    				conn_to_device = memcmp(PERIPH_MATCH_DATA, adv_data_structs[i].data, PERIPH_MATCH_DATA_LEN) ? false : true;
    	#endif
    				break;
    #endif
    			case GAP_AD_TYPE_TRANSMIT_POWER:
    				dev_found = true;
    				int8_t power;
    				memcpy(&power, adv_data_structs[i].data, 1);
    				dbg_block_printf("TX_POWER: %i dBm\r\n", power);
    				break;
    #endif
    #if (SCAN_FILTER == SCAN_FILTER_16_BIT_SVC_DATA || SCAN_FILTER == SCAN_FILTER_NONE)
    			case GAP_AD_TYPE_SERVICE_16_BIT_DATA:
    				dev_found = true;
    				uint16_t UUID;
    				memcpy(&UUID, adv_data_structs[i].data, sizeof(uint16_t));
    				dbg_block_printf("GAP_TYPE: SVC_DATA_16_BIT: UUID:%04X DATA:%s\r\n",
    														UUID, format_hex_string(adv_data_structs[i].data+2, adv_data_structs[i].len-2) );
    				break;
    #endif
    #if (SCAN_FILTER == SCAN_FILTER_MFG_DATA || SCAN_FILTER == SCAN_FILTER_NONE)
    			case GAP_AD_TYPE_MANU_SPECIFIC_DATA:
    				dev_found = true;
    				dbg_block_printf("MFG_SPECIFIC_DATA: %s\r\n",
    				break;
    #endif
    			default:
    				dev_found = true;
    				dbg_block_printf("GAP Type: %02x, Data: %s\r\n", adv_data_structs[i].type,
    #endif
    				break;
    	if(dev_found){
    		uint8_t rssi_abs = 256 - adv_ind->report.rssi;
    		dbg_block_printf("RSSI: -%d\r\n", rssi_abs);
    		dbg_block_printf("BD_ADDR:%s \r\n---------------END_ADV-----------\r\n",
    																						format_bd_address(&adv_ind->report.adv_addr) );
    	if(conn_to_device)
    		dbg_block_printf("Connecting to Device...\r\n", NULL);
    		central_app_env.connect_to_periph = true;
    		memcpy(&central_app_env.connect_to_addr, &dev_addr, sizeof(struct bd_addr));
    		central_app_env.connect_to_addr_type = adv_ind->report.adv_addr_type;
    		user_ble_gap_stop_scan();
    	#endif
    In the Central example, we filter the advertising report by Device Name and we are checking for the DLG-PROXR name. The name is being handled by the PERIPH_MATCH_DATA macro on the user_central_config.h file.
    When we find the correct name that matches with the one declared on PERIPH_MATCH_DATA we set the conn_to_device variable to TRUE. This will result in storing this specific advertising report information and call the user_ble_gap_stop_scan API to stop the scan procedure.
    3) When the Scan procedure stops, the user_on_scanning_completed callback function is executed. In that callback function we use the user_ble_gap_connect API to initiate the connection.
     * @brief Callback from SDK when scan completed.
     * @param[in] reason reason for stopping the scan procedure
     * @return void
    void user_on_scanning_completed(uint8_t reason)
    	if(reason == GAP_ERR_CANCELED)
    		user_ble_gap_connect(central_app_env.connect_to_addr.addr, central_app_env.connect_to_addr_type);
    		central_app_env.connection_timer = app_easy_timer(CONNECTION_TIMEOUT_10MS, connection_timeout_cb);
    	else{
    		dbg_printf("%s: ERR: reason: %d\r\n", __func__, reason);
    In your scenario, you could either change the PERIPH_MATCH_DATA macro to match your Device name or you could filter based on other parameters and use the conn_to_device variable in order to stop scanning and inititate the connection.
    OV_Renesas
  • Thank you very much; I can now connect the DA14531 and the external sensor.
    The external sensor operates via AT commands, so I want to periodically send certain AT commands, receive the responses, and pass them via UART to a host microcontroller. My approach is as follows:
    • At the end of the connection, start a timer after discovering all the services:
    void user_on_connection(uint8_t connection_idx, struct gapc_connection_req_ind const *param)
    user_gatt_discover_all_services(connection_idx, 1);
    periodic_timer = app_easy_timer(5000, timer_callback_function);
    • Periodically, the timer should call the timer_callback_function, which handles writing AT commands.
    From the output terminal, I see that the sensor connection index is 0x0000, the service of interest is 0xfff0, and the characteristic of interest is 0xfff2, which is the only one I can write to. For istance, the output terminal shows:
    handle_svc_ind: conn_idx=0000 start_h=0013 end_h=0018
    0xfff0:
       0015 char 0xfff1 prop=12 (-R--N---)
       0018 char 0xfff2 prop=0c (--XW----)
    Completion Event: GATTC_DISC_ALL_SVC: status: 0000
    Completion Event: GATTC_WRITE
    So, for timer_callback_function(), my plan is to:
    - Write the AT commands, example:
    user_ble_gatt_write(GATTC_WRITE_NO_RESPONSE, 0x0000, 0xfff2, at_command, data_len);
    - Restart the timer:
    In conclusion, with the timer_callback_function, I plan to send the AT command, receive the response, and later print the response using dbg_printf.
    Am I missing anything or doing something incorrectly in this procedure?
    Thank youfor your time,
    Regards.
  • Hi Seba,
    Thank you for the reply.
    I would personally start or call directly a function to control the AT commands on the static void handle_service_disc_finished(uint8_t con_idx) callback function that will be executed when all available services have been discovered.
    You are also utilizing the user_ble_gatt_write API the wrong way. Please refer on the user_ble_gatt.c/h files:
     * @brief Perform a gatt write
     * @param[in] con_idx - connection identifier
     * @param[in] handle - attribute handle to write
     * @param[in] data - data to write
     * @param[in] data_len - data len
     * @return void
    void user_ble_gatt_write(uint8_t op, uint8_t con_idx, uint16_t handle, uint8_t *data, uint16_t data_len);
    On the parameters, we give the characteristic handler and not the UUID of the characteristic.
    That would mean, that your call should look like this:
    user_ble_gatt_write(GATTC_WRITE_NO_RESPONSE, connection_idx0x0018, at_command, data_len);
    Where connection_idx variable has been taken from the user_on_connection callback function and 0x0018 corresponds to the char 0xfff2 with the Write Permission.
    OV_Renesas
  • All clear, thanks!
    To recap, I need to work with the following characteristics (verified through a smartphone app):
    • Service UUID: 0000fff0
    • Read characteristic: 0000fff1 (handle 0015), properties: Read, Notify
    • Write characteristic: 0000fff2 (handle 0018), properties: Write
    For my goal of sending AT commands and directly printing the responses on the terminal, I imagine I need to enable the notification service.
    Currently, based on your suggestion, I have only added the following line:
    user_ble_gatt_write(GATTC_WRITE_NO_RESPONSE, con_idx, 0x0018, at_command, data_len);
    in the static void handle_service_disc_finished(uint8_t con_idx) function.
    This alone of course doesn’t produce any output on the terminal.
    By adding the following command:
    user_gatt_read_simple(con_idx, 0x0015);
    along with the modification in user_catch_rest_hndl:
    case GATTC_READ_IND:
    			struct gattc_read_ind const *ind = (struct gattc_read_ind const*)param;
    #ifdef ENABLE_BAS
    			if(ind->handle == central_app_env.periph_devices[conn_idx].serv_disc.bas_char.c.value_handle)
    				dbg_printf("Battery Level Read: %d \r\n", ind->value[0]);
    			}else
    #endif
    				dbg_printf("GATTC_READ_IND: handle: %04x\r\n", ind->handle);
    				for (int i = 0; i < ind->length; i++) {
    					dbg_printf("%02X ", ind->value[i]);
    		}break;
    I get the following on the terminal:
    GATTC_READ_IND: handle: 0015
    GATTC_READ: status: 0000
    So, the reading is successful.
    Is there a way to achieve this using the notification service, without having to perform a direct read?
    Thank you, and I apologize for the continued disturbance.
  • Hi Seba,
    Just for clarification: Notifications are not a service. Notify is a Permission of the Service or the Characteristics. From the central side you can subscribe or unsubscribe in order to receive Notifications.
    This can be achieved with the following API:
     * @brief Register for notifications/indications for specific service
     * @param[in] svc - service to parse
     * @return void
    void user_register_notification(uint8_t conidx, struct gattc_sdp_svc_ind const *disc_svc)
        if( disc_svc->start_hdl != ATT_INVALID_HANDLE)
            //register profile task in gatt for indication/notifications
            struct gattc_reg_to_peer_evt_cmd * reg = KE_MSG_ALLOC(GATTC_REG_TO_PEER_EVT_CMD,
                    KE_BUILD_ID(TASK_GATTC, conidx), TASK_APP,
                    gattc_reg_to_peer_evt_cmd);
            reg->operation =  GATTC_REGISTER;
            reg->start_hdl = disc_svc->start_hdl;
            reg->end_hdl =   disc_svc->end_hdl;
            ke_msg_send(reg);
    //On the header file:
    void user_register_notification(uint8_t conidx, struct gattc_sdp_svc_ind const *disc_svc);
    You can call this API after you have discovered a Service, and the DA14531 (Central) will subscribe to the Notifications for this specific Service and its characteristics.
    Whenever you receive a Notification, the case GATTC_EVENT_IND will be triggered on the user_catch_rest_hndl function.
    OV_Renesas
  • Good Morning,
    To recap, I inserted the function you suggested here in  user_catch_rest_hndl:
    case GATTC_SDP_SVC_IND:
    struct gattc_sdp_svc_ind const *disc_svc = (struct gattc_sdp_svc_ind const *)(param);
    uint8_t con_idx = KE_IDX_GET(src_id);
    if (disc_svc->start_hdl == 0x0013 && disc_svc->end_hdl == 0x0018)
    dbg_printf("Service 0xfff0 found, registering for notifications...\r\n", NULL);
    user_register_notification(con_idx, disc_svc);
    handle_svc_ind(con_idx, disc_svc);
    }break;
    with the goal of subscribing to the service discussed in previous questions for receiving notification.
    In the static void handle_service_disc_finished function, I inserted the usual command:
    user_ble_gatt_write(GATTC_WRITE, 0x0000, 0x0018, &temp, sizeof(temp));
    which I am sure works correctly, as the sensor receives it and lights up some LEDs.
    At this point, with notifications enabled and the following modified section:
    #ifdef ENABLE_BAS
    			}else
    #endif
    					dbg_printf("%04x\r\n", ind->value[i]);  // Stampa i dati in formato esadecimale
    		}break;
    Should I expect that the data from the characteristic with handle 0x0015 will be notified and printed on the screen?
    This is very important because I need to interface a host microcontroller with the external sensor via BLE. Therefore, I have to monitor the entire process to see and understand what data are being sent.
    Thank for your time.
  • Hi Seba,
    I would personally subscribe on the notifications of this specific service on the handle_svc_ind function when we discover the services. But I believe your implementation should work as well.
    To verify if it worked, please add the following case on the user_catch_rest_hndl:
    			case GATTC_REGISTER:
    				dbg_printf("GATTC_REGISTER: status: %04x \r\n", evt->status);
    			break;
    You are checking on the case related to the Read request.
    You should check on the GATTC_EVENT_IND
    		case GATTC_EVENT_IND:
    			struct gattc_event_ind const *ind = (struct gattc_event_ind const *)param;
    #ifdef ENABLE_BAS
    				dbg_printf("Battery Level Changed: %d \r\n", ind->value[0]);
    #endif
    		}break;
    The Proximity reporter example has the Battery Service implemented, which will sent notifications when the Battery level has changed. The Central receives the Notification on the GATTC_EVENT_IND case.
    Please add another if statement that compares your characteristic UUID with the ind->handle and then you can print out the data you received from the ind->value variable.
    OV_Renesas
  • Thank you, this was very useful.
    Now I can send AT commands and view the corresponding responses.
    Thank you very much for your valuable guidance!!
    Regards.
