For the PTX30W,
I see that everything is done via buffer 0 .
What does it represent ?
And can I access arbitrary T2T blocks?
i also don't see HIP Read using any buffer for its operations?
/** Write the message (currently only message buffer 0 is in use). */
Hi DS4,Thank you for posting your question online.Let me check on this and I will get back to you as soon as possible.Best Regards,OV_Renesas
Hi DS4,Apologies for the delay.Normally you shall not access any arbitrary block.If the user needs to exchange proprietary data, they must use the Transparent data channel.Please elaborate more the needs of your application so we can come with more precise details.Please feel free to create a private ticket regarding this questions.Best Regards,OV_Renesas
