Iam using eclipse IDE 2024-06 (4.32.0), when I build DA16200_DA16600_SDK_FreeRTOS_v3.2.8.1 project related to DA16600 mod getting compilation error as show below.
Wl,--start-group -lumac -llmac.mod -lcryptopkg -lromac -Wl,--end-group", ...) failed.
make (e=87): The parameter is incorrect.
make[1]: *** [makefile:194: da16600.elf] Error 87
make: *** [makefile:185: all] Error 2
"make all" terminated with exit code 2. Build might be incomplete.
Build Failed. 2 errors, 0 warnings.
Hi Manoj,Thank you for posting your question online.Please refer on UM-WI-056 DA16200 DA16600 FreeRTOS Getting Started Guide (renesas.com), on section 5.2 System Requirements, page:33Please download e2 Studio IDE (Eclipse based) and you will be able to compile the SDK.Best Regards,OV_Renesas
