CM33 如何提取 A55 发送的数据?
static int rpmsg_endpoint_cb1 (struct rpmsg_endpoint * cb_rp_ept, void * data, size_t len, uint32_t src, void * priv)
/* service 1 */
(void) priv;
(void) src;
/* On reception of a shutdown we signal the application to terminate */
if ((*(unsigned int *) data) == SHUTDOWN_MSG)
evt_svc_unbind[1] = 1;
return RPMSG_SUCCESS;
/* Send data back to master */
if (rpmsg_send(cb_rp_ept, data, (int) len) < 0)
LPERROR("rpmsg_send failed\n");
return -1;
在上面的函数里,如何把 data 里的数据提取出来和把 CM33 处理后的数据发送回 A55?
