GTM 如何使用?
#include "r_gtm.h"
#include "r_rspi.h"
FSP_HEADER
/** GTM Timer Instance */
extern const timer_instance_t g_timer0;
/** Access the GTM instance using these structures when calling API functions directly (::p_api is not used). */
extern gtm_instance_ctrl_t g_timer0_ctrl;
extern const timer_cfg_t g_timer0_cfg;
#ifndef Timer_1S_callback
void Timer_1S_callback(timer_callback_args_t *p_args);
#endif
在 e2 开发环境中定义了 GTM 定时器,如何让定时中断工作?
#include "User_program_thread.h"
#include "FreeRTOS.h"
#include "openamp/open_amp.h"
#include "platform_info.h"
#include "rsc_table.h"
LPRINTF("Timer_1S is running--- \n");
/* User program Thread entry function */
/* pvParameters contains TaskHandle_t */
void User_program_thread_entry(void *pvParameters) {
FSP_PARAMETER_NOT_USED(pvParameters);
LPRINTF("User Program is running--- \n");
while (1)
vTaskDelay(1);
在上述程序中定时中断未被执行,没在串口终端打印出内容。
  • 请问有在主函数里初始化并启用timer吗?
  • #include "User_program.h"
    void g_timer0_callback(timer_callback_args_t *p_args)
    LPRINTF("g_timer0_callback is running--- \n");
    /* User task Thread entry function */
    void User_program_entry(void *pvParameters) {
    LPRINTF("User program is running--- \n");
    fsp_err_t err = FSP_SUCCESS;
    /* Initializes the module. */
    err = R_GTM_Open(&g_timer0_ctrl, &g_timer0_cfg);
    /* Handle any errors. This function should be defined by the user. */
    assert(FSP_SUCCESS == err);
    /* Start the timer. */
    (void) R_GTM_Start(&g_timer0_ctrl);
    /* (Optional) Stop the timer. */
    //(void) R_GTM_Stop(&g_timer_ctrl);
    while (1) {
    vTaskDelay(1);
    初始化也不行
  • gtm_instance_ctrl_t g_timer0_ctrl;
    const gtm_extended_cfg_t g_timer0_extend = { .generate_interrupt_when_starts =
    GTM_GIWS_TYPE_ENABLED, .gtm_mode = GTM_TIMER_MODE_INTERVAL, };
    const timer_cfg_t g_timer0_cfg = { .mode = TIMER_MODE_PERIODIC, .period_counts =
    (uint32_t) 0x98967f /* Actual period: 0.1 seconds. */, .channel = 1,
    .p_callback = g_timer0_callback, .p_context = NULL, .cycle_end_ipl = 5,
    .p_extend = &g_timer0_extend,
    #if defined(VECTOR_NUMBER_GTM1_COUNTER_OVERFLOW)
    .cycle_end_irq = VECTOR_NUMBER_GTM1_COUNTER_OVERFLOW,
    #else
    .cycle_end_irq = GTM1_OSTM1INT_IRQn,
    #endif
    /* Instance structure to use this module. */
    const timer_instance_t g_timer0 = { .p_ctrl = &g_timer0_ctrl, .p_cfg =
    &g_timer0_cfg, .p_api = &g_timer_on_gtm };
    extern uint32_t g_fsp_common_thread_count;
    const rm_freertos_port_parameters_t User_program_parameters = { .p_context =
    (void*) NULL, };
  • 配置看起来没问题,你看看中断里加一下断点或者定义个counter看看没进中断还是进中断没有打印
  • /* TODO: add your own code here */
    这个打印了
    }    这句不打印,说明中断没发生
    开发板没引出仿真接口,没办法实时仿真 CM33,只能通过串口打印来观察程序执行
  • 如果你的LPRINTF是基于中断实现的,那么在timer中断里打印可能异常
  • uint32_t timer0_count=0;
    //LPRINTF("g_timer0_callback is running--- \n");
    timer0_count++;
    while (1) {
    LPRINTF("timer0_count = %u \n", timer0_count);
    vTaskDelay(1000);
    运行结果:
    Successfully probed IPI device
    Successfully open uio device: 42F00000.rsctbl.
    Successfully added memory device 42F00000.rsctbl.
    Successfully open uio device: 43000000.vring-ctl0.
    Successfully added memory device 43000000.vring-ctl0.
    Successfully open uio device: 43200000.vring-shm0.
    Successfully added memory device 43200000.vring-shm0.
    Initialize remoteproc successfully.
    creating remoteproc virtio
    initializing rpmsg vdev
    timer0_count = 1
    timer0_count = 11
    timer0_count = 21
    定时器工作了,但只打印了 3 行就停了
