Hello,I want to know about a PROM, its model number is HS-6664RH. I would like to know the programming operation of this memory because I did not find the operation of data writing in the datasheet.
Thank you!
Hi Yang0068,
It seems like the details that you are looking is not publicly shared. I would suggest that you submit a ticket to Renesas Technical Support for this request: https://en-support.renesas.com…
It seems like the details that you are looking is not publicly shared. I would suggest that you submit a ticket to Renesas Technical Support for this request: https://en-support.renesas.com/dashboard
JBRenesasRulz Forum Moderator
https://renesasrulz.com/https://academy.renesas.com/https://en-support.renesas.com/knowledgeBase/
