RE01 R7F0E015D2CFP#AA1 Setting the Option-Setting Memory
The following is the description of the manual:
Setting Data for Programming Option-Setting Memory :
(1) Changing the Option-Setting Memory by Self-Programming
(2) Debugging through an OCD or Programming by a Flash Memory Writer
The manual describes OFS registers as read-only, so how to set them?
The manual says that there are two methods for setting the above, is there a more detailed sample and step description,
Thank you!
