RAJ240045 How does the chip export firmware data and what hardware should be used? What software? ,芯片怎么导出固件数据,应该用什么硬件,什么软件
  • The chip has no firmware programmed in the device.  Information on how to program this device is covered under NDA.  This device is targeted for very large companies that use many thousands a year.  They will program the unit based on their battery configuration.
    This will require that you would work with your local Renesas Sales to start this process.
