DA9070 Unused Outputs
Are there recommended connections for both an unused LDO and an unused Buck on the 9070 PMIC?
Thanks!
  • Hi There, sorry for delay. Generally speaking, if you disable the unused bucks and LDO, should be able to leave the output floating. Having said that, we'd need to check /review the proposed OTP config just to check there are no unintended effects. BR JE_REN
