DA7282 waveform memory examples
I got the HAL code for the driver, but are there any examples of what to fill the waveform memory with to get certain effects? That would be super helpful rather than reinventing that wheel.
  • Hello,
    The GUI download should come with library files, these files will be set-up scripts for specific LRA/ERMs and waveform examples.
    You will need to go into the waveform editor and open the script to see the examples.
    If, we do not have a script for the LRA you plan on using then one will need to be generated.
    Kind regards,
    ED
