ZMOD4450 Arduino Uno Air Quality Change Rate constantly 0
ZMOD4450EVZ Arduino Uno Air Quality Change Rate constantly 0
Hi, using Arduino IDE with the IDT_ZMOD4450-Firmware_SWR_20200306.zip together with SparkX ZMOD4450 I2C Driver (sparkfun/SparkFun_Refrigeration_Gas_Sensor_ZMOD4450_Qwiic (github.com)) and LibPrintf.
The inital code's I2c was not working due to the stop condition being sent during the read operation (between the write address and the read data). That was fixed by changing Wire.endTransmission(); to Wire.endTransmission(false); I also added the driver sleep function using the arduino bulitin delay function.
Then i linked the code together with the precompiled files in raq-libraries\atmega32\avr5 by copying the files to an arduino library at the location src\atmega328p\ and adding "precompiled=true" and "ldflags=-l_avr5_raq" to the library.properties file.
After replacing many include statements and fixing some compilation errors in the api example the code compiles successfully.
But i have a problem which is the raq: air quality change rate is always at 0.000000 while the 2 other values are changing: Rmox seems to be working since it first slowly increase to around 190 kOhm and settle at 130 kOhm then if i put the sensor into a food box it slowly drop to around 90 kOhm. the raq: control state changes erratically but most of the time its 2817 and 3073 (I couldnt find out how to interpret the value?)
Since the raq code is precompiled, I don't know if this is the intended behavior. Hopefully someone can release the code (So that we can use in other microcontrollers like esp8266, PIC, ATTiny) or add more documentation into the datasheet.
Any help would be appreciated. Thanks.
  • hi There, i had the following feedback from the apps team :
    "Looks like something is wrong in the code.  RAQ is defined as the following per data sheet:
    In short words: The RAQ is a simple highpass filter over the resistance (with a time constant of 60min), which can easily be programmed by everybody.
    Also, the ZMOD4450-EVK manual will give some more additional details."
  • Thanks, but I don’t quite understand what you mean.
    Are you saying I should be programming code to get RAQ from the rmox resistance myself? ( I’m not sure whats the recommended formula and algorithm for the 60min high pass filter. Plus there is no function provided to get the rmox resistance without the raq values which means i have no choice but to use the precompiled code instead of writing my own code to read the registers directly)
    Also, how do I figure out if the problem is with my code or the precompiled raq code provided by renesas? ( The licence prevents me from disassembling the precompiled code. )
  • Hello Jren, as mentioned in the message above the raq value should be greater or lower than 1. Values of 2817 we can assume as "out of range". I gave the Arduino example a quick try but cannot get it to run to be honest. Could you share your folder from documents/arduino/libraries/zmod4450? And also an output from the serial monitor over ~ 10 -20 minutes?
  • reading.txt
    zmod44xx_read_sensor_info
    zmod44xx_init_sensor
    zmod44xx_init_measurement
    Evaluate measurements in a loop. Press any key to quit.
    Measurement:
      Rmox  =   186 kOhm
      raq: control state: Sensor not stabilized
      raq: Air Quality Change Rate: Sensor not stabilized
    Measurement:
      Rmox  =   195 kOhm
    Measurement:
      Rmox  =   205 kOhm
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   212 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   212 kOhm
    Measurement:
      Rmox  =   212 kOhm
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   211 kOhm
      raq: control state -13568
      raq: Air Quality Change Rate 0.000000
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 1536
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 5376
    Measurement:
      Rmox  =   211 kOhm
      raq: control state 24832
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 24576
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -4096
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -6144
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -11008
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -1280
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 16640
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -13056
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -2304
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -32512
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -14848
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 26368
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 20480
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 5120
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -16640
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -18176
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 16384
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 25088
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 26624
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -15360
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -31488
    Measurement:
      Rmox  =   211 kOhm
      raq: control state 10752
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -26624
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 16896
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 13312
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 24064
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 7680
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -3072
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -28672
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 11264
    Measurement:
      Rmox  =   209 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 22528
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 8448
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -3328
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -9984
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 6144
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -25088
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 9728
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 9984
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -8192
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 2304
    Measurement:
      Rmox  =   207 kOhm
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -30976
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 17152
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 3840
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 22016
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 17920
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 9216
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -9216
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 26880
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 12288
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 32512
    Measurement:
      Rmox  =   206 kOhm
      raq: control state -14592
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 30976
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -23296
    Measurement:
      Rmox  =   207 kOhm
      raq: control state -30464
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 4608
    Measurement:
      Rmox  =   207 kOhm
      raq: control state 27904
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -8704
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 23552
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -10752
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 7168
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 23296
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -27648
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -29696
    Measurement:
      Rmox  =   207 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 28160
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -25856
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 20992
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state 6912
    Measurement:
      Rmox  =   207 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -29952
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   208 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -21248
    Measurement:
      Rmox  =   209 kOhm
      raq: control state -27136
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -7424
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   212 kOhm
      raq: control state -20736
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   208 kOhm
      raq: control state -12288
    Measurement:
      Rmox  =   209 kOhm
      raq: control state 0
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 3584
    Measurement:
      Rmox  =   211 kOhm
      raq: control state 11520
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -24832
    Measurement:
      Rmox  =   212 kOhm
      raq: control state 18176
    Measurement:
      Rmox  =   210 kOhm
      raq: control state -23552
    Measurement:
      Rmox  =   210 kOhm
      raq: control state 27648
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   211 kOhm
      raq: control state -18944
    Measurement:
      Rmox  =   211 kOhm
      raq: control state -7680
    Measurement:
      Rmox  =   209 kOhm
    Measurement:
      Rmox  =   211 kOhm
      raq: control state -32768
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   212 kOhm
      raq: control state 30464
    Measurement:
      Rmox  =   210 kOhm
    Measurement:
      Rmox  =   211 kOhm
    Measurement:
      Rmox  =   213 kOhm
    Measurement:
      Rmox  =   213 kOhm
      raq: control state 3328
    Measurement:
      Rmox  =   212 kOhm
    Measurement:
      Rmox  =   212 kOhm
    Measurement:
      Rmox  =   214 kOhm
      raq: control state -13824
    Measurement:
      Rmox  =   213 kOhm
      raq: control state -31744
    Measurement:
      Rmox  =   214 kOhm
      raq: control state -21504
    Measurement:
      Rmox  =   213 kOhm
    Measurement:
      Rmox  =   216 kOhm
      raq: control state -24064
    Measurement:
      Rmox  =   216 kOhm
      raq: control state 21248
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state -6656
    Measurement:
      Rmox  =   219 kOhm
      raq: control state 25856
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   217 kOhm
      raq: control state -14336
    Measurement:
      Rmox  =   217 kOhm
      raq: control state 30720
    Measurement:
      Rmox  =   219 kOhm
      raq: control state 28416
    Measurement:
      Rmox  =   217 kOhm
      raq: control state 19456
    Measurement:
      Rmox  =   217 kOhm
      raq: control state 20224
    Measurement:
      Rmox  =   216 kOhm
    Measurement:
      Rmox  =   217 kOhm
      raq: control state -7168
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state -12032
    Measurement:
      Rmox  =   218 kOhm
      raq: control state 7936
    Measurement:
      Rmox  =   215 kOhm
      raq: control state 14848
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state -26880
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state -1792
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 11776
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state -27392
    Measurement:
      Rmox  =   220 kOhm
      raq: control state -5888
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 28928
    Measurement:
      Rmox  =   221 kOhm
      raq: control state 28672
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 6400
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state -7936
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state 30208
    Measurement:
      Rmox  =   220 kOhm
      raq: control state -8960
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state -6912
    Measurement:
      Rmox  =   219 kOhm
      raq: control state -25344
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 31744
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   219 kOhm
      raq: control state 15104
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 12032
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 31488
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 2560
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   222 kOhm
      raq: control state 29696
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   221 kOhm
      raq: control state 11008
    Measurement:
      Rmox  =   221 kOhm
      raq: control state 32000
    Measurement:
      Rmox  =   220 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   223 kOhm
      raq: control state 19968
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -20224
    Measurement:
      Rmox  =   225 kOhm
      raq: control state -23040
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -32256
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   221 kOhm
      raq: control state -22272
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -17920
    Measurement:
      Rmox  =   222 kOhm
      raq: control state -2560
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -24320
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   232 kOhm
      raq: control state 4864
    Measurement:
      Rmox  =   250 kOhm
      raq: control state -14080
    Measurement:
      Rmox  =   263 kOhm
    Measurement:
      Rmox  =   268 kOhm
    Measurement:
      Rmox  =   255 kOhm
    Measurement:
      Rmox  =   241 kOhm
      raq: control state -18432
    Measurement:
      Rmox  =   248 kOhm
    Measurement:
      Rmox  =   242 kOhm
    Measurement:
      Rmox  =   239 kOhm
    Measurement:
      Rmox  =   240 kOhm
    Measurement:
      Rmox  =   241 kOhm
    Measurement:
      Rmox  =   240 kOhm
    Measurement:
      Rmox  =   239 kOhm
    Measurement:
      Rmox  =   239 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   232 kOhm
      raq: control state 13824
    Measurement:
      Rmox  =   234 kOhm
      raq: control state -4608
    Measurement:
      Rmox  =   233 kOhm
      raq: control state -15872
    Measurement:
      Rmox  =   235 kOhm
    Measurement:
      Rmox  =   234 kOhm
    Measurement:
      Rmox  =   233 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   231 kOhm
      raq: control state -12800
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   232 kOhm
    Measurement:
      Rmox  =   231 kOhm
    Measurement:
      Rmox  =   231 kOhm
      raq: control state -26112
    Measurement:
      Rmox  =   231 kOhm
    Measurement:
      Rmox  =   229 kOhm
      raq: control state -1024
    Measurement:
      Rmox  =   229 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   228 kOhm
      raq: control state -10496
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   227 kOhm
      raq: control state -22784
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   225 kOhm
      raq: control state 8704
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   225 kOhm
      raq: control state 13568
    Measurement:
      Rmox  =   224 kOhm
      raq: control state -21760
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   223 kOhm
      raq: control state 29952
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 27136
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 18432
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   222 kOhm
      raq: control state 1024
    Measurement:
      Rmox  =   221 kOhm
      raq: control state 19712
    Measurement:
      Rmox  =   222 kOhm
      raq: control state 8192
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   224 kOhm
      raq: control state -17408
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   223 kOhm
      raq: control state 19200
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   227 kOhm
      raq: control state 14080
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state 29184
    Measurement:
      Rmox  =   228 kOhm
      raq: control state -19456
    Measurement:
      Rmox  =   226 kOhm
      raq: control state -30720
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   225 kOhm
      raq: control state 7424
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state -16896
    Measurement:
      Rmox  =   227 kOhm
      raq: control state -29184
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 12544
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
      raq: control state -29440
    Measurement:
      Rmox  =   226 kOhm
      raq: control state -17152
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 15360
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 22784
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   222 kOhm
      raq: control state -23808
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -10240
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   223 kOhm
      raq: control state -9728
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 17408
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   224 kOhm
      raq: control state -4864
    Measurement:
      Rmox  =   224 kOhm
      raq: control state 18688
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   227 kOhm
      raq: control state 31232
    Measurement:
      Rmox  =   227 kOhm
      raq: control state -4352
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   229 kOhm
      raq: control state -8448
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state -22528
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   230 kOhm
      raq: control state 20736
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   229 kOhm
      raq: control state -18688
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   229 kOhm
      raq: control state -28416
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   229 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   230 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
      raq: control state -19968
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state 15872
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state 26112
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   224 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   227 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   226 kOhm
      raq: control state 13056
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   226 kOhm
    Measurement:
      Rmox  =   228 kOhm
    Measurement:
      Rmox  =   225 kOhm
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   218 kOhm
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   218 kOhm
      raq: control state 29440
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   220 kOhm
      raq: control state 9472
    Measurement:
      Rmox  =   219 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   222 kOhm
    Measurement:
      Rmox  =   221 kOhm
    Measurement:
      Rmox  =   222 kOhm
      raq: control state -12544
    Measurement:
      Rmox  =   223 kOhm
    Measurement:
      Rmox  =   222 kOhm
    seems like the new reading is different from last time
