Programming the XTL312625.000000I oscillator.
I'm currently in design phase with the XTL312625.000000I oscillator.
Based on my understanding, it looks like this specific PN support I2C configuration, is this correct ?
I found the register and programming procedure but I would like to make sure that this PN support this feature.
If it does not support I2C are SDA/SCL internally connected to the die ?
